Self serve account
raymondroussell
How to create a Self Serve account
@raymondroussell
Simple…just active your new PM SIM and use your personal email address.
You can purchase a new SIM from a Telus/Koodo store.
Don’t use your work email just encase you leave your job or let go.
@raymondroussell you started a similar post yesterday about not able to login My Account,  do you remember you ever login there?
either way, open s Firgot Password ticket and PM support will confirm ot help you to setup one
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or if you have trouble with Chatbot,  Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
popping
@raymondroussell
Self-serve account is created at the end of the activation process.  Use your email address as the username and the password provided to login to your account.
dabr
Are you activating as a new customer?  Then click this link to activate your new SIM/self serve account:  https://activate.publicmobile.ca/
If you're already a customer and never created a self serve account, you will need to contact customer support and ask them to create the self serve account for you, here:  https://urlshortner.tiia.ai/XZxMjt
Quigley
@raymondroussell
Up top on the menu click on , Getting Started.
You'll be able to create your self service account during your activation of your sim card and plan.
You can't create a self service account if you don't activate your sim and plan.
If you activated you're sim card and plan in store a long time ago, and didn't get a self service account then.
Then you'll have to get a Customer Support Agent to help with that.
Use the Chatbot Simon to get a service ticket started first.
