12-19-2022 06:26 PM
I need to change the email I use for login/contact. I have switched providers and no longer have that email address. How do I change this.
My Account
12-19-2022 06:31 PM - edited 12-19-2022 06:31 PM
There are 2 places this should be changed:
- in your Self-Serve account: follow CSA contact as @Yummy provides to contact the support agents, and
- in your Community account: you can easily do this by tapping your
icon upper right of your screen, go down to My Settings, and update your new e-mail address there. Doing this ensures a smooth use of support services in future as both Community and Self-Serve e-mails match.
12-19-2022 06:27 PM
Only agent can update your email.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
