07-03-2024
03:11 PM
07-03-2024
05:04 PM
computergeek541
Hi all,
For the second time in 6 months, I said to myself let's give it a try with PM, their 15$ unlimited plan is too good to be true.
For the second time in 6 months, I get stuck with an activation error obviously AFTER my CC got charged. What is wrong with you guys? Any other activation I went through all my life went smoothly no issues and twice stuck with PM.
What can I do? I already sent a message to CS_Agent to cancel immediately my account I was so frustrated.
Any way I can make this thing WORK??
07-04-2024 09:01 AM
@Dannicha They are usually fairly quick but sometimes when there is a lot they have to deal with it can take much longer, but don't expect a response overnight, their hours are 9 a.m. to 10 p.m. eastern time.
07-03-2024 06:27 PM
Have done so...what is typical response time?
07-03-2024 06:24 PM
just message support agent then
07-03-2024 06:23 PM
I am having exactly the same issue...multiple times. Stuck at Step 6, Subscription not Activated
07-03-2024 06:06 PM
Are both your registered postal code on your account match the registered CC postal code?
07-03-2024 03:18 PM
what make/model cellphone ?
Use this link to message Customer Support...request your concern be escalated as you've been trying for several months to activate.
07-03-2024 03:17 PM
Thanks for the heads up, I actually don't need data since I use my workplace data plan. I only need to keep my personal number and be reachable.
07-03-2024 03:15 PM
I downloaded the app and the last message I get is Step 6 of 6, Activate - Subscription not activated, something didn't go right while activating your subscription. Click below to contact a CS agent.
07-03-2024 03:15 PM
Yes, I downloaded the app and the last message I get is Step 6 of 6, Activate - Subscription not activated, something didn't go right while activating your subscription. Click below to contact a CS agent.
07-03-2024 03:13 PM
did you download the free PM app to activate the new acct ? Be aware the current $15 plan doesn't include and data...best option is the $19 plan with talk/text and some data.
07-03-2024 03:13 PM
@Flo-Al how far in the process are you getting? What is the actual message you are receiving?
