Self serve account access
Weswhite
Does anyone know what to do when you cant access you account to pay you bill? I cant log info self serve keeps saying my email is invalid. I had to create a new email and create a new community account just to sign info the community!
10 REPLIES 10
popping
@Weswhite wrote:
I got several differnt messages through various attemps but the Mail one was invalid email but i thanks my free email serve closed up shop so i couldnt access my account to change it
Only moderatore can access your account.
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
Weswhite
Yesterday i will give it a go thanks
Triguy
You can buy a voucher and call 611 to make a payment or use recharge.com.
@Weswhite  use @Staliger 's suggestion and contact the moderators.
Weswhite
What is the exact message that you get when you try to login? And were you on a grandfathered 90 day plan? Thanks.
@Weswhite wrote:
I did that two days in a row with no response only way of contact with the is my email as my serve was suspended because i couldnt reload my account!
Weswhite
gblackma
@Weswhite You can use 611 See link on how to use 611.
https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352#M20315
Use the 611 service. You can top up using a pre-registered payment card or use a voucher from a store or online.
Staliger
@Weswhite To solve the issue, contact moderators : click the "?" in lower right side of the page, type "contact moderator", and follow directions (give as much info as possible), OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
