Cancelled Account Need old bills
Lucieintheskyyy
Hello, I cancelled my account and need access to my bills - can these be sent to me somehow or how do I access since I've lost online access?
@eddieO wrote:
@Lucieintheskyyy try reaching out to a support agent for help with getting these.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
As the OP has no active PM account, the chatbot is useless'er then it usually is !
eddieO
hairbag1
@Lucieintheskyyy
message Customer Support using this link...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
give them old number  and name on acct.
hi @Lucieintheskyyy
you cannot access the My Account anymore after your account is closed.  But PM support agent can send you the invoices, you can submit  ticket by direct message:
