01-19-2025 05:47 PM
im locked out of my account and my phone was stolen... i need to reset my password and get my login code so i can get into my account!!!
I already PMd the team this is urgent, I have access to the email and this is a business line
My Account
01-19-2025 06:38 PM
FYI....response time is about 2 hours today.
01-19-2025 06:07 PM
@mbmbmb I already PMd the team this is urgent
How long ago did you PM them? Are you checking the envelope icon top right of this page or, if you don't see an envelope, tapping your avatar to access messages for their reply? You aren't likely to get an immediate response so you may have to wait a while (hopefully within an hour or two but could be longer). Is there no way to disable your phone either through Apple's Find My or the Android equivalent ?
01-19-2025 06:04 PM
As long as you can verify you are the account holder customer support can/will access your account to perform those particular duties.
I can private message you what details you need to provide to the agent verify if necessary.
01-19-2025 05:59 PM
how can they do that if i cant get into my account?
01-19-2025 05:58 PM
it doesnt send anything, nor does it send a password reset!!
01-19-2025 05:57 PM
You can ask customer support to suspend your account via lost/stolen. Even better purchase a new sim card and get the agent to perform a sim swap.
01-19-2025 05:55 PM
trying to see if i can get into the voicemail 😞
01-19-2025 05:54 PM
its not sending to my email thats the problem 😞
01-19-2025 05:51 PM - edited 01-19-2025 11:45 PM
@mbmbmb wrote:im locked out of my account and my phone was stolen... i need to reset my password and get my login code so i can get into my account!!!
You can try getting into your self serve account by having he code sent by e-mail or by voice messages (which you can check by dialing your phone number from a different phone). If neither of those options are available, you'll have to continue working with a Public Mobile customer support agent. Threads in this message forum are usually only seen by other customers who can't assist with issues with your account.
01-19-2025 05:51 PM
@mbmbmb If you have access to the email, then when you go to log in and get to the page where you enter the code, tap "didn't get the code" and it should give you the option to get it by email.
