Forbidden A1
MoeinAbtahi
I recently transferred my number from Virgin to Public Mobile. After activating my number with Public Mobile, I can no longer access my account. Every time I log in, I only see the "Forbidden A1" error message and nothing else.
Could you please help me resolve this issue?
@MoeinAbtahi
Try clearing the cache on your browser before login and see if that helps.
MoeinAbtahi
Thank you!
@MoeinAbtahi
ok, use this link to message Customer Support to help set up your new account....
MoeinAbtahi
Yes, everything is set up, and my eSIM with Public Mobile is working fine. The only issue I’m facing now is with my Public Mobile account.
hairbag1
@MoeinAbtahi
you were to leave old sim in your cell to be able to receive text confirming your port request. Did you reply YES to that message ?
clipped from Help Files...
https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
