Account locked
Odi1
Hello,
Can’t enter my wife’s account. On desktop it notifies “A1 forbidden”, on app doesn’t enter.
anyone can help?
 Thanks
Odi1
Thank you very much.
@Odi1 now you need to ask PM to help then
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Odi1
That didn’t work unfortunately.
TheSterlinger
Usually if you sign into the account with secret or incognito mode it will work. To clear or refresh the App pull down from the top of the screen 2-3 times.
