iphone visual voicemail
ningairline
I see people recording a voicemail but when I go into my iphone voicemail list with the visual voicemail, it doesn't show in the list. Where did the voicemail go?
2 REPLIES 2
Phil_Adelphus
@ningairline   Are you trying to find them in your Public Mobile voicemail?  To access the Live Voicemail messages you tap the voicemail icon bottom right of the phone app.
hi @ningairline
Visual voicemail is not supported with PM
if you meant Live Voicemail, you can disable it to avoid the notification confusion
