Change credit card for auto payments
cojan1999
How do I change my credit card account for auto payments
2 REPLIES 2
geopublic
@cojan1999
Setting up AutoPay means that you earn $2 every 30 days!
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
Note: When entering the postal code do not enter any spaces. Also do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
darlicious
@cojan1999  Log into your account. Go to the make a payment page. Scroll down to bottom of page. Click on manage cards. Click on replace credit card. Not remove. Replace credit card info. Do this using a clear browser and secret/incognito mode preferably using chrome or Firefox.
