Self Serve Account not recognizing my new password
natenodin
Cannot login to self serve page. Have tried resetting my password multiple times - public mobile keeps saying invalid password, how do I fix this ?
Thanks in advance.
natenodin
Tried clearing the cache and cookies, also tried incognito mode with no luck yet.
Quigley
@natenodin
Try logging into your account using a different browser in incognito or private mode instead.
Try again.
HI @natenodin
Try to clear cache first and login again
If not work, try using private/incognito/secret mode
if still does not work, maybe the password didn't reset properly?  Open ticket with CS agent and they can help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Try logging in again incognito mode private mode or  even from another device or lap top , there are cache issues
@natenodin could be just browser cache issue
Please try again using Incognito mode and it should work
