12-27-2022 10:37 AM
I received a Season bonus from P Mobile ( 500min intern.calls), but my account shows only 300min ( out of which more than 100min have been used already - but I did not use them 😞
How could I recover the missing 200min plus 100 min ?! Thanks
12-27-2022 10:46 AM
HI @Yonge23140 you see the bonus data as well?
you should see two addons like this:
2GB 2GB one-time data bonus
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-27-2022 10:45 AM - edited 12-27-2022 11:02 AM
The holiday add on shows 300/500min left? Or the add on is 300min entirely? Were your holiday gifts added automatically or thru customer support? It sounds like you have the $15/300 international minutes add on rather than the promotional holiday gift? A screenshot of the add on would be very helpful.
Edit: Last year's "more is merrier" holiday gifts add on and this year's look identical....
The "more is merrier " holiday gifts.
Please increase the image limit I keep searching for hidden images to delete to upload a new picture.....I will run out of those soon too?!!
12-27-2022 10:44 AM
@Yonge23140 @Refresh page when signed in
12-27-2022 10:42 AM
You should see 2GB and 500 int. mins on your account if bonus has been added properly. Try to refresh your account page.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-27-2022 10:40 AM
@Yonge23140 the 300 mins you see must be a different bonus addon , it could be browser cache issue
Pleae login My Account again using incognito mode to assure you get the updated correct info
if still not see the bonus, please open ticket with PM Support and they will add it back for you
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
