a month ago
My subscription package includes 250gb of data plus the 24mth bonus of 10gb data per month for a total of 260gb. The package renews on the 11th and I've run out of data already and purchased a 15gb $30 addon. However the website is not recognizing it as 15gb and reports my total allowance as 265gb instead of 275gb. It reports that my usage a day later after purchasing the addon is 263.44gb and the system has already sent me warnings of running out of data when I should have 11.6gb of data roughly left. The subscription renews in 2 days and I shouldn't have to purchase another addon when I should have 11gb remaining. I'm guessing when I purchased the addon, it was calculating the total as being my base 250gb package without taking into account the 10gb 24mth bonus. Any help in getting this resolved would be appreciated. As a senior on a fixed income this package is perfect for my phone and internet needs...well ..maybe I could use a bit more data 🙂
a month ago
Thank you, that seems to be a pretty clear path, and the URLs are very helpful. Cheers!
a month ago
Best to contact a CS_Agent and ask for a credit for the Add-on data that you purchased since it hasn’t been used due to low data warning.
a month ago
hi @DrHook
did you really use that much data? check PM support agent to see if the 10GB is still there
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
