My plan
Diana22
I accepted a plan offer that was sent to me by text message on May 17, but I still don't see it reflected in my mobile data. Could you please tell me why? Has the promotion been applied to my account?
2 REPLIES 2
slusagm
maybe browser cache problem.  Try login using browser with Incognito mode.  If you still not seeing the correct plan, then ask PM to help
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
CSA_PM
Customer Support Agent
Hello @ Diana22,
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
