08-01-2026
10:52 AM
- last edited
4 weeks ago
Dunkman
After returning from Europe and removing my travel eSIM, the MMS Messaging option disappeared from my iPhone 14. I also no longer have a Cellular Data Network menu. I can’t send photos or links to Android phones. Can you reprovision my line and verify my carrier settings?”
08-09-2026 09:23 AM - edited 08-09-2026 09:25 AM
hi @Kdhd
then submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
08-09-2026 06:49 AM
Thanks but non of these solutions helped. I give yo
08-01-2026 07:08 PM
Physical sim or eSIM?
If you have a physical sim, test it in another phone. But if you have an eSIM, you can get a new eSIM and the issue will be resolved. But a new eSIM using PM app and buy from Account -> Purchase Sim card, choose eSIM
08-01-2026 07:06 PM
And I tried the support staff and they didn’t help.
08-01-2026 07:05 PM
I tried that no luck
08-01-2026 10:58 AM
hi @Kdhd
check and delete all VPN profiles
Reboot your phone and reset network settings
and make sure PM sim is enabled and set with label Primary
08-01-2026 10:54 AM
try doing a network re-set to see if that helps restore service. In settings, make sure the Public Mobile esim is now set to primary.
