SIM not working
claudiata
I signed up my daughter into Public mobile and registered a sim card got a new number, payment went through but not signal not connection, nothing. I need help
claudiata
I rebooted the phone and it works now 🙂 Thank you!!!
@claudiata  Try rebooting the phone . And if possible can you try sim card in another phone to test . If no dice . It’s possible you need to submit ticket with support to re provision the sim for you on their end .
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
@claudiata
Try to reseat the sim card once.
Also, you can try to click Reset All Networks
If still does not help, likely a sim provisioning issue.  Easy fix for PM support and you just need to open ticket with them by messaging here
HALIMACS
@claudiata
Try rebooting device, resetting network connections, and toggling airplane mode on/off.
Also, try the PM SIM card in another (known to be working) device to see if service works with it.
Then you'll be able to determine whether device or account/SIM issue.
