Porting Problem?
07-02-2024
12:55 PM
07-02-2024
04:08 PM
computergeek541
Hi. I referred a friend and his account is active but his number isn't working. When you call his number it says, "6UT1, the number you have reached is not in service". And the top right corner of his phone says, "SOS" instead of having the PM service bars. So is this a porting problem? If so how can we fix it? Pleaseeeee help! Thank you
Joining Public
07-02-2024 01:22 PM - edited 07-02-2024 01:23 PM
Try rebooting the phone by powering off then back on and reset the Network settings.
Also clean the SIM contacts with a microfibre cloth.
07-02-2024 01:05 PM
@Maebo_T is this a physical SIM? He can test sim card in your phone.
Sometimes resetting networks works.
If not, he can sign into his account and submit a ticket.
Or by direct message below.
