SIM card is need or not for 4g plan to 5g plan
bobyk
Hi,
I have one question, recently i changed my 4G plan to 5G plan. It should purchase any 5G sim or continue on same sim card  ????
thanks
Boby
Phil_Adelphus
@bobyk   I switched from a 3G plan to a 5G plan with the same sim card, no problem at all.
Terryscell
Your SIM card will work at all speeds. No need to change.
slusagm
same sim card.
so, you have problem using 5G? was it why you asked? What phone you have?
HI @bobyk
you don't need to change sim card, the same sim card will work on 4G or 5G, only the phone matters in this case
Chalupa_Batman
@bobyk wrote:
Hi,
thanks
Boby
Hey @bobyk
Negative. All PM SIM cards work on 3G 4G and 5G. No need for a new card at all. Also, if your phone can do eSIM, the first one is $5 and everyone after that is free. However, I'd stick with the physical SIM card as you can swap it into pretty much any phone within moments. eSIM you can't.
