iPhone 11 Pro - 5G?
6Jeffer6
Hi,  I have an IPhone 11 Pro and would like to go to the 5G plan for $35.00.  I believe 5G only works with IPhone 12 and newer.  I plan to upgrade my phone in the next few months.  If I change to the $35 plan, will my phone still work properly? Thanks,  Jeff
2 REPLIES 2
6Jeffer6
Thanks very much!  Just wanted to make sure the phone would perform properly!
slusagm
the 5G just a plan speed.  With your iPhone 11, you can still get the 5G plan and enjoy the "5G speed", which is up to 250Mpbs, using only 4G LTE.  So, you can change plan without problem
