02-27-2023 12:11 PM
I purchase US roaming add on and it's not working, your robot service is useless
02-27-2023 10:06 PM
@IMEI wrote:Some good troubleshooting in the Q& A of this link
U.S. Roaming (publicmobile.ca)
..interesting, the page updated about the lenght of the roaming (from 10 to 15), but it still kep AT&T as the roaming partner, while almost all of those who tried confirmed that we cannot connect to AT&T at all.
02-27-2023 09:56 PM
02-27-2023 03:08 PM
Your comments are not going to Public Mobile customer service. This community page is all customers just like you.
Provide some details and ask for help. That’s what the community is here for.
02-27-2023 12:46 PM
@Abraham1 - are you in the USA? Roaming addons are for use only whilst in USA.
Please let us know more of the issue so we can try and help.
02-27-2023 12:15 PM
@Abraham1 Also if your trying to re buy there very same US add on you have to wait 12-24 hours after the first one ends to re buy very same US add on or you can choose a different US add on … support however can manually put the re buy of the very same add on with out any delay
Watch for reply top of page to the
Right ( envelope image )
02-27-2023 12:14 PM
02-27-2023 12:13 PM
@Abraham1 what kind of roaming did you get? voice or data?
data is probably easier to connect, voice might be harder
First make sure you are connected to T-Mobile. If it is not, try to manually connected to it
If you have data , make sure you enable Mobile Data roaming on your phone
02-27-2023 12:12 PM
@Abraham1 Make sure your connected to T mobile and reboot the device
