$15 plan
zhengbe2
In $15 plan, it includes 100 minutes of Canada-wide callings. Does it calculated on the outgoing calling or calculated on the outgoing and incoming callings?
10 REPLIES 10
poutinecity
Good catch.  Thanks. Edited accordingly.
zhengbe2
I love the answer.
Thanks
@zhengbe2   the page shows that because it was setup long time ago when there was another plan that even incoming calls will be using minutes.
Again, all current plan has incoming calls for free, so answer calls won't count against your 100 minutes on your $15 plan
@zhengbe2      That page was wrong.  I have $15 plan too and I can confirm answer incoming calls does not counted toward your 100 minutes from your plan.
zhengbe2
Thanks for the information.
I checked the link you provided and noticed that answering calls counted into the minutes.
I am not sure if the answering calls are incoming calls.
@poutinecity wrote:
The 100 minutes includes outgoing and incoming calls.
@poutinecity - are you referring to the in current market $15 plan? Because if so, you are incorrect in your statement.
The in current $15 market plan is for 100 outgoing minutes ONLY.
mw311
The information provided by @@poutinecity is false. See @Dunkman’s Reply for valuable add-on suggestion.
Dunkman
@zhengbe2
Here is some more information:
https://www.publicmobile.ca/en/ab/get-help/articles/limited-talk-and-text-plans
Unlimited incoming minutes as mentioned.  Rounds up to the nearest minute. Checking voice mail and call forwarding does use up minutes.  A good idea to purchase the $5 for 500 Canada wide minutes just in case.  Unused minutes rolls over each payment cycle.
@zhengbe2 incoming minutes are free on all current plans
poutinecity
The 100 minutes includes outgoing calls. Incoming should be included with your plan.
