12-11-2024 04:34 PM
I payed for a US roaming and calling add on. However, I am still unable to call US numbers from Canada. Does this add on only work when I am in the US, or if there some settings I have to change to be able to call US numbers from Canada?
12-11-2024 06:05 PM
Looks like you purchase the wrong Add-on if you are calling from Canada. You need the LD calling and not Roaming (only if you are in the USA). Unused time will be rolled over to the next month.
Here are the prices:
12-11-2024 04:44 PM
hi @CanJam
the US roaming is for you to call US and Canada from US only, not from Canada. You need to buy the US long distance calling
please ask support to refund the wrong add-on so you can go and rebuy the correct US Long Distance addon
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
12-11-2024 04:44 PM - edited 12-11-2024 04:45 PM
Make sure you add the area code before when you dial. I'm assuming that you have a North America calling plan.
12-11-2024 04:44 PM - edited 12-11-2024 04:53 PM
@CanJam the US add-on only works while in the US.
If you want to call the US, you have to buy the long distance plan for $15.
I hope they will credit you back for the incorrect one purchased. Common error done by many.
