11-29-2023 05:38 PM
12-02-2023 05:28 PM
Thank you all for your support. I followed all the instructions and it never worked. I’m back in Canada. Waiting answe for my refund request.
11-29-2023 05:44 PM
Hi @Mia120,
You will need to connect to AT&T or T-Mobile network on your Network Selection for service in the USA. One network might be stronger than the other based on wherever you are located so try switching between both to see which is faster!
To enable the roaming option you will need to go to your Settings and enable Data Roaming.
11-29-2023 05:42 PM
@Mia120 reboot your phone and Put you phone to LTE and select T mobile or AT&T also ensure you have data roaming turned on in phone settings see if this helps . Also does you phone support voLTE do you know . But if it just won’t work you can request a credit by submitting ticket with support
send a private message To CS_Agents click
VVVVV Link below VVVVV
11-29-2023 05:40 PM - edited 11-29-2023 05:41 PM
you could ask for credit to your account for the failed add-on. Message the CSA and ask.
added...
