12-02-2024 05:48 PM
Hi my friend is having issues after porting.
She cannot log into her account.
Her text is not working.
Can someone post a link here for me to forward to her to send private message for customer support thank you.
12-02-2024 06:41 PM
Thank you! She can make calls and receive calls but texting does not work. She has an iPhone.
12-02-2024 05:50 PM
hi @Lileea
can she make calls or data work?
if she can make calls and just not able to receive inbound calls, then she can call the porting support team, I will message you the number to your community inbox
but if she cannot even make calls, that is not a porting problem but account setup problem, message support instead. submit ticket by direct message:
12-02-2024 05:50 PM
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
