12-02-2024
05:17 PM
12-03-2024
08:28 AM
computergeek541
Recently changed from Telus to Public Mobile (Telus) and now when I receive a SMS with a picture it just spins and eventually times out saying "not available". Although I received a few others that will download but most fail. I am using Google messages as my default messaging app but have tried the stock app and Textra etc. with the same results.
12-02-2024 06:31 PM
It was the APN settings. Port and proxy needed changed. Strange I've switched multiple times before and never had to edit APN. Anyways thanks for your assistance 👍
12-02-2024 05:43 PM
hi @Willie68
what brand and model your phone?
check the APN and make sure these are there
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
12-02-2024 05:42 PM
Yes it is
12-02-2024 05:42 PM
MMS and data are turned on
12-02-2024 05:36 PM
12-02-2024 05:35 PM - edited 12-02-2024 05:35 PM
@Willie68 Make sure you have MMS enabled and cell data turned in to send and recieve picture messages
