Monday
Can't update credit card in website under the payment section - info will not enter. Is there a way to do it without downloading the app?
Tuesday
@hrsc Ah, then it's not related to any special character. In that case other uses' reply are much more useful than mine. 😅
Tuesday
Tuesday
can only enter the postal code, won't let me put in the card #, expiry or security code...
Monday
@hrsc Try using incognito/private browsing mode and see if it works.
Monday
Any particular field that you cannot enter the info? Card Number, Postal Code, Expiry Date, or Security Code?
