Roaming in Mexico
03-05-2025
12:24 PM
03-05-2025
03:57 PM
computergeek541
Hi there. I'm seeing previous posts that you can use your public mobile plan/phone in Mexico. However, all the add-on/subscription plans I'm seeing mentions US only. Is there a way for me to roam in Mexico with my public mobile plan? Is this done with the US Roaming add-on? How is this possible?
03-05-2025 12:48 PM
for a short trip to Mexico, consider getting a Telcel sim and a cheap plan to be able to talk with folks at home. Cost is about $20 for 30 days of talk / text / data and you can call most any Canada and US number...even works when you get back home. If you plan on being a frequent traveller to US and Mx, consider getting one of the currently offered Canada / US / Mexico plans...they work just as good as if you were in Canada.
03-05-2025 12:28 PM
HI @MartinaP1
sorry, no one off add-on for Mexico roaming
you can change to Canada/US/Mexico plan. But please be aware if you planning to change to the roaming plan for just one month for the trip, it might not worth it as you might not be able to change back to your current plan
03-05-2025 12:26 PM
You have to have Can/USA/Mex Plan in order to use service in all 3 countries.
PM does not have add-on for Mex only.
