How to disable roaming?
brembo153
I have a CAN/US/MEXICO plan, and I'm going to be traveling from Canada to the US shortly. I'd like to avoid any roaming charges. Is there a way to disable roaming ? I'm assuming my data will still work in the US, since it's a CAN/US/MEXICO plan, but I don't want to get any roaming charges if someone from Canada calls/texts me while I'm in the US
7 REPLIES 7
@brembo153
I've had my roaming enabled since 2018, traveled to US and Mexico and haven't ever received a bill for overages. As as pre-paid service, once you reach your data limit...it just stops until next regular plan renewal (or you buy an add-on). There's no charge to you to receive calls and texts from anywhere on planet Earth. Enable Roaming is a must to be able to use the service in Mx and USA.
hi @brembo153
receiving would be free as well
brembo153
@slusagm Thanks for the reply, that answers my 2nd concern !
brembo153
@hTideGnow thanks for the reply !
I'm worried more specifically about calls/texts from Canada to me while I'm in the US. My plan includes 100 mins for long distance calls, so I'm assuming I'm safe there. But would I get charged for international texts ?
slusagm
no extra roaming charges.  PM is prepaid and you will never get any unexpected charges
and with your plan, even when someone from Canada call and text you , you can receive them for free in US
hi @brembo153
you don't need to disable it when you travel to US.  Calls, text and data are all included in your CAN/US/MEXICO plan, no extra. In fact, you need to enable Roaming Data on  your phone for your service to work in US
brembo153
Forgot to mention, I'm using an iPhone with IOS 18
