Rewards
06-18-2024 12:40 PM
06-18-2024 04:42 PM
You need to log in to your account, go to my rewards, browse the catalogue. If you accumulate at least 15 points, you can redeem $15 dollar bill credit that will be applied on your next bill. It is not applied automatically even if you have 15 or more points.
06-18-2024 01:52 PM
Here's a how-to thread by @darlicious. It's shows how to do it specifically for reactivation but the process is the same.
06-18-2024 12:45 PM - edited 06-18-2024 12:47 PM
Just login to the PM app and click on the Rewards tab>Browse Catalogue>Redeem if you have collected 15 points or more.
06-18-2024 12:42 PM
HI @Henryma222
you can redeem for $15 bill credit whenever you have 15 points
Login to My Account, click Rewards and go to My Rewards site. Then go ot Redeem and look for $15 bill credit. And remember, you can only redeem bill credit after you have 15 points there
