07-02-2019 09:30 AM - edited 01-05-2022 05:41 AM
Attn:Customer care services
Sir,
As agreed and paid for service to maintain my phone number after I return from my trip to Africa(March 5th to June 29th,2019 my account and phone number will be reinstated and the same plan will be reestablish
Please address this ASAP
Thank you,
xxxx
removed personal info by mimmo
07-02-2019 09:52 AM
@sheik_rashid18 Welcome back. can you please detail what was agreed and by who?
are you able to loginto selfserve with your account info? if so simply do a plan chnage to teh plan you want?
if you are unable to loginto selfserve most likly your account has been deactivated as you probably have were without service for more than 90 days.
the people on this board are customers like you. for account related issues you need to contact moderator_team via private message. but the more details you provide here will help us direct you to teh best solution.
07-02-2019 09:50 AM
It is more than 90 days between March 5th and today.
When did your last renewal date?
Can you still login to you self serve account?
If not, you account may be cancelled already.
07-02-2019 09:45 AM
You may also want to edit your quote of OP's original message. It also has personal information on it.
07-02-2019 09:38 AM
Did you make any payments ? You can leave the account inactive for up to 90 days.
https://www.publicmobile.ca/en/bc/get-help/articles/reactivate-a-suspended-plan
07-02-2019 09:36 AM
I would remove private info as this is a public forum.
Also, could you provide a little more detail in case the community may help you?
07-02-2019 09:35 AM - edited 07-02-2019 10:43 AM
@sheik_rashid18 for you protection you should remove your private information ASAP. If your account was not active from more than 90 days you account gets deactivated. If you had issues with AutoPay and your account got suspended then you need to contact PM.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-02-2019 09:35 AM - edited 07-02-2019 09:48 AM
@sheik_rashid18 wrote:Attn:Customer care services
Sir,
Thank you,
Canada
H4C 1X
Tel:xxx-xxx-xxxx
This is a public Forum, so I suggest you remove all your priviate info. Click the three dots in upper righthand side of dialogue screen to edit out personal info.
