07-02-2019 10:04 AM - edited 01-05-2022 05:41 AM
Hi having problems porting my number from Fido - landline. It’s been three days and still hasn’t ported. SIM activated and I can use my cell to call out however phone still ringing at home instead of cell. Thanks in advance.
07-02-2019 10:12 AM
Thanks for the response- I’ll take your advice.
07-02-2019 10:06 AM
Landlines and VOIP lines can take up to one week to port. Mobile lines usually port within 24 hours.
You could wait another 1-2 days. If not ported, you could contact moderator to have a look at the status (or you could even ask now since it takes 1-2 days to respond)
Send a private message to moderator through the following link :
07-02-2019 10:05 AM - edited 07-02-2019 10:06 AM
@Sajj69Landline typically takes longer.. so patience is required. It took me 5 - 6 days to port my landline.
