Retrieve sms messages for at least 7 days
ChanteleLouise
Hi there. My account will only show me 2 days not 7 days may you please help
2 REPLIES 2
@ChanteleLouise  You should be able to see 3 months back in history on main page of self serve
Check add-ons /mins /Data
note where it’s says view usage history bottom of pic
@ChanteleLouise   Are you talking about the Usage history page?  DO NOT use the filter.  The filter has some problem if you apply it too early. Just go through each day.  Or download the Usage history in xls and use Excel to filter instead
Check my post about the filter glitch on Usage page
https://productioncommunity.publicmobile.ca/t5/Get-Support/Usage-History-page-Filter-problem/td-p/84...
