Retrieve old phone number
rawanelayoubi
I need to retrieve my old phone number back. the number was 647-763-XXXX. I need to add a new number to my account alongside the existing number I have. any help would be appreciated.
Thank you
7 REPLIES 7
francyfrance
Old number started with 705 area code and the number ended with 73
Yummy
- You cannot get your old number back as most likely it was reassigned. If you are extremely lucky (start playing Lotto right away) and phone number belonged to Telus family and it is not assigned (number not in service) it might appear on a list of available numbers and you can take it then.
- You cannot get multiple phone numbers on one account. Each account has only one phone number and one unique email.
hycm53
@rawanelayoubi PM doesn't allow two phone numbers in one account, PM doesn't have any share plan or family plan like the other provider such as Rogers, etc. That means one phone number in one account for PM customers.
Metal1967
@rawanelayoubichancesare.. the number is lost.. doesn’t hurt to try..
toppy
@rawanelayoubi this is public forum, please cover your personal info
@rawanelayoubi   you might want to remove the phone number for your protection
So, you don't have the number anymore?
The number 647-763-xxxx belongs to Telus, which PM has access to.
Usually, carrier will no longer assign exact number to customers. However, you can try to open ticket with PM Support to see if they agree to give it back to you once you joined.  of course, it will be easier it you can show them you owned the number before and you lost it not too long ag
To open ticket with PM, please message them:
walker1
@rawanelayoubi  Sorry you can only have one phone number per account.
What happened to your old phone number that you have to get it back, so bad?
