Renew my subscription
MamaWiju
Using the *611 dial service what do they mean by the 4 digit account pin
CSA_PM
Customer Support Agent
Hello @ MamaWiju,
I sent you a private message. You can view it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@MamaWiju you will need PM to help with the account login
 Since your account is locked, you will need support agent to help.  Please send them a message
@MamaWiju
For some reason, your email address is not connected with your account.  I will try to escalate your post to CSA_PM who should be able to help you access your account. Response times should be 30 minutes.
MamaWiju
It's very frustrating
MamaWiju
When I try to login it gets stuck at activate your subscription page yet I am already an existing member
hairbag1
@MamaWiju
when you set up your Public Mobile account it asks you to have a pin number. You can log in to your account > click the Account tab...scroll down to Reset Pin Number.
