02-03-2025
06:24 PM
02-03-2025
08:12 PM
computergeek541
On the app it shows my data use currently at 2.84 gb which has been stuck at this amount since I activated. The web site shows current use at 4.80 which is an accurate reflection of my use. How can I reset the App to show my actually usage ???
Thursday
02-04-2025 12:13 PM
no need to repeat others nearly 18 hours alter
02-03-2025 06:30 PM
hi @DavePierce
the app sometimes does not update without manual push. Swipe the screen down to force and uopdate.
or better, logout from the app and login again
02-03-2025 06:26 PM - edited 02-03-2025 06:27 PM
@DavePierce wrote:On the app it shows my data use currently at 2.84 gb which has been stuck at this amount since I activated. The web site shows current use at 4.80 which is an accurate reflection of my use. How can I reset the App to show my actually usage ???
Hey @DavePierce
If you put your finger at the top of the page and drag down, it will spring back up with an updated amount. If it's still the same after that, go into your app settings and clear your cache and restart phone. If you're using an iPhone, delete app and redownload it.
