Renew my plan immediately
Zobair
Hi
My plan will be activated on May 2.
But I need to activate it now.
Please activate it for me.
Thank you
hairbag1
@Zobair wrote:
Hi
Thank you
If you've run outta talk minutes, you can just get 500 minutes of Canada wide calling add-on for $5. That way you don't have to renew your plan...the add-on minutes are used until your next renewal. Any unused add-on minutes will just roll over until you use them up...even if that takes several months or longer.
Log in to your account to Purchase Add-ons. Make sure you put $5 in Available Funds, before you make add-on selection.
JL9
Unless you are changing your plan to a different one you will have to wait for CSA to reply as you cannot renew the same plan immediately.
@Zobair   We are all just customers here  😞
But PM Support usually reply quick.  Just make sure you have enough fund loaded.  They usually reply quick
If you want a quick way to "renew"... You can do this by changing your plan.
Just go to My Account and select Change Plan and pick a different plan from your current one and select Change plan now.  PM will them automatically charge you the new plan amount  and start a new cycle immediately. That is the quickest way but you do need to change the plan.  You can change back to your old plan later for your next cycle.  **if you go this way, make sure you reply CS Agent and ask them not to manual renew your plan again as you already made a manual plan change
Zobair
Hi
Yes, exactly it is what I want to do.
But I do not have enough time to wait. I need to activate my plan soon now.
Could you help me, please?
i sent a private message but am not sure if they will activate my plan soon.
thank you
devrajking1314
Chat with https://publicmobile.ca/en/ab/chatbot
Your issue will be solved
@Zobair   did you mean your plan will be renewed on May 2 but would like to have early renewal?
If so, load enough fund in the account and open a ticket with PM Support and ask them to manually  renew your plan early
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
