Sim card doesn't fit
Steve_Froese
I received and loaded 2 different sim cards for Public mobile yesterday. I was advised that your sim cards will fit the S5, S6 and S8 Samsung phones. I attempted to fit the sim card into the S5 phone and it would not fit. What do I do? I put the card into another phone I have but that isn't the one I want to use.
Spudster
@Steve_Froese
See these pics for visual descriptions of the SIM card and adapters:
@Steve_Froese
The SIM comes with 2 spacers you need to carefully snap off to fit.
The S5 will probably need the Micro spacer and the S6 & S8 you need the nano and doesn’t need any spacer.
JL9
Did you get the 3 in 1? You just need to pick the right size sim depending on the phone?
hairbag1
Have a look here ...see if this helps.
https://www.youtube.com/watch?v=2pPr1M1HbSo
edit...added second vid...
https://www.youtube.com/watch?v=EduZUfTsSkM
