Subscription change
Xmenak
Hey guys, I just signed up with the $29 10gb plan (black friday deal) however I need more data and set the $35 50gb plan to renew instead for my next cycle. Since these deals are over on dec 2nd will I still get my plan change at the end of dec?
Genuine
You will get the new plan at your next renewal date.
Yummy
Usually PM is good in regards of honouring a renewal of promo plan Even after promo is expired.
Since you DID select new (promo) plan to be switched to on next renewal you Should get it!
Nevertheless it will be good if you have any proof (screenprint, etc.) you did select plan in case you have to engage agent to give you that plan if PM fails.
HI @Xmenak
you can use Change now to make the immediate plan change, but the unused days on your current $29 plans will be forfeited with no partial refunds
you can also use Change on Renewal to lock in the deal for next renewal
but if you don't do anything and change it after today, the deal might be gone
hairbag1
@Xmenak
the plan change will load your new plan on next renewal date.
