07-14-2022
01:50 PM
07-14-2022
01:52 PM
computergeek541
Hello,
I was visiting canada and my daughter got public mobile sim from a shop. We said them to do payment by month as i was only visitor in canada. Now i am back to Pakistan. I don’t have sim. And i am not using number since 10th june. I discarded sim as i never knew that payment is still been deducted from my daughters card. I don’t have any account with you online nor shopkeeper told me. Money has been deducted from my daughter credit card. And i got two numbers. For myself and for my husband too.
kindly please remove credit card from both accounts. She should be refunded the amount as me and my husband didn’t used sim and shopkeeper didn’t told us anything. It’s so disappointing.
1- xxxxxxxxxx
2- xxxxxxxxxxxxx
My Account
Payment
Service
07-25-2022 04:56 PM
Yes indeed, the manage payment option was simply not functioning when I tried to update my Cc information. It is working now.
Dennis
07-14-2022 05:11 PM
Either have your daughter call 1 855 4PUBLIC and enter the 10 digit phone number associated to the accounts. Record the date of renewal. On day 30 of the current plan cycle she can put a hold on her card before midnight eastern. At noon eastern about 12 hours later she can call 1 855 4PUBLIC again and check that the accounts are now suspended for non payment. Once she confirms suspension she can remove the card hold. The accounts will be cancelled and deactivated 90 days later.
07-14-2022 02:11 PM
HI @dspilde
Yes,you can remove the Autopay
But I saw posts about there is no way to remove the credit card on the new My Account at the moment.
I think we can also suggest OP to disable Autopay , but OP activated in store, I have a feeling they never setup the Self-serve My Account
07-14-2022 02:05 PM
Not true, you can manage your own payment methods when it works.
07-14-2022 01:55 PM
Unfortunately, there is no option to remove a credit card from within the Self Serve account. You will need to.contact a customer support agent by opening a ticket through: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
07-14-2022 01:53 PM
contact a cs agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type request email and new password
2. alternatively you can private message them here
07-14-2022 01:52 PM - edited 07-14-2022 01:52 PM
HI@rahatariq The proper way is to ask PM Support to remove the credit card on the account for you
However, since you are won't be using the service any more and you left Canada already, the best way in this case is to ask your credit card to make a charge back, cancel the transactions. Then your accounts will be closed immediately
