Email
Taylorhallett88
Hi I've forgotten me email and password what do I do.
MrSpock
@Taylorhallett88 Hi if you can’t remember your email get a cs agent to reset it for you,  or you can use a current one you will need to open a ticket, to contact  a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:   https://bit.ly/2GGCJzH
@Taylorhallett88
You have a chance to try to reset the password yourself?
At My Account's Forgot Password,  https://myaccount.publicmobile.ca/en/forgot-password
 Just put any email address you could have used and see which one works and gets you to step 2
If none of them work, open ticket with PM Support
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
