Referral code funds not applied
Jens2
I have sent my referral code to two friends who signed up in the last month. Neither they nor I received the $10 from the referral.
How long does it typically take? I haven't referred someone since PM changed to the new rewards system last year
Dunkman
@Jens2
Just to add, you will not get $10 credit as referer.  You will receive one refer-a-friend reward point per payment cycle (equivalent to $1) as long as your friend stays with Public mobile.  New customer will get the $10 credit usually within 72 hours.
As mentioned, your friend (new customer) has to contact CSA to get this sorted out.
eddieO
@Jens2 samething just happened to my father, I helped set him up last week with my referral code and there was still no $10 credit in his account. He had to reach out to a support agent where they said the code was not entered properly so they added it in for him, they said it should be there within 72 hours. Create a ticket and they will add it for you.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
@Jens2
usually the $10 credit will be added to the new subscribers within 72 hours.  Since it has been more than that, please have your friend to submit a ticket with CS agent and they will add it back if missed
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
