Referral - Additionnal lines
RPH
Good evening everyone,
I tested the serice and am happy with it. I have 4 lines to port over. Mine, my wife's and 2 kids. As I am paying for all 4 and also managing all the lines, I was wondering what was the best way to proceed to get the most benefits in terms of rewards.
Thanks
Robert
Darren21
I am doing exactly what the others are suggesting. I am porting my number first and getting the account setup and then getting the refferal for the other accounts we are bringing from the same household. The billing can all be setup on the same credit card. Why not take advantage of a $10 per additional line as well as the public points for the main refferal account it's a win win.
DennyCrane
You can refer your own lines. I would suggest that the line you think will be around the longest (less likely to be swayed for a deal with another carrier) be the one to sign up first and refer the others.
golfball
You get 1 reward point for each referral every 30 days and you can redeem points for a bill credit at 15 points. You probably want to refer all other accounts to your account so that 15 points can be accumulated more quickly.
hi @RPH
since you are the one paying for all the lines, it really doesn't matter how you proceed with the rewards
But if you think line 1 (the one you have tested with PM ) will stay and won't go away, an easy way is to use the code for this line 1 for activating line 2 , 3 and 4
and a reminder, PM system is simply, one email for one line only.  So, you will need 3 other emails for your other 3 lines
hairbag1
@RPH
you can use your referal for each new account. You'll need a unique email address for each account but if you use gmail, they support alias's.
