01-23-2022 09:57 PM - edited 01-26-2022 12:58 AM
I transferred my phone number on Jan 16. Since then I’ve been unable to receive incoming calls.
Update Jan 25,2022: It was a porting issue. Once I called the # they resent the request to authorize changing numbers and providers. The phone was working within the hour. Thank you to everyone for their suggestions and support!
01-26-2022 12:56 AM
Msged the # to you. Hope this works for you as well!
01-26-2022 12:55 AM
Thank you for offering a solution! It was a porting issue and it was resolved when the # change request was resent. All resolved!
01-25-2022 07:28 PM
Can you please message me the number as well? Thank you.
01-24-2022 06:13 AM
@Jaskg wrote:I transferred my phone number on Jan 16. Since then I’ve been unable to receive incoming calls.
@Jaskg - have you tried any of the below?
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
01-23-2022 10:55 PM
I just sent you a private message with a phone number you can call just to confirm that your porting request was completed successfully. If calling that number does not resolve your issue, the only other way to get support from PM would be to send a private message to CS_Agent with your account details.
01-23-2022 10:12 PM
01-23-2022 10:02 PM - edited 01-23-2022 10:02 PM
01-23-2022 10:01 PM
Yes, I did receive a text from my previous provider with the # change request and I replied YES
01-23-2022 09:59 PM - edited 01-23-2022 10:00 PM
@Jaskg did you get a text from your previous provider and did you reply YES to it?
It looks to me it is a stuck port. I will message you a phone number to call and get the porting status. They can help to re-trigger the porting text. Check the Community inbox , envelope icon on top right
01-23-2022 09:59 PM - edited 01-24-2022 12:42 AM
Have you texted yes to the number when you initiated the transfer?
