08-19-2025 07:49 AM
I recently just switched to PM from Rogers and the whole family did.
experiencing 3G data and no service when in basement. Rogers I was getting steady coverage.
I switched to the 5g 80gb plan
any suggestions on possible fixes or reasons?
08-19-2025 11:15 AM
Hi Brando1000
Just a guess but maybe your calls were using wifi calling in the basement. Rogers supports wifi calling Public Mobile does not
08-19-2025 11:14 AM - edited 08-19-2025 11:15 AM
08-19-2025 10:24 AM
You might also want to check the nearest cell tower to your main location. Maybe the nearest Telus/Bell tower is further away than the nearest Roger's tower.
08-19-2025 08:19 AM
What phone do your have?
you mentioned about 3G data, but why 3G if you have a 5G plan? Make sure network mode is set as Automatic And try again. Also try setting the network mode to 4G LTE
