10-04-2022 07:57 PM
My plan includes unlimited incoming calls and 100 outgoing minutes per cycle. My current cycle is September 22 to October 21. My account says I've reached my 100 minute limit and I can't make any calls. I only have one incoming call for 37 minutes and one out going call for 1 minute both on October 1st. Any idea why my account shows I've reached my limit, and how do I fix it?
10-10-2022 01:45 PM
Is your phone originally bought from Telus? Did you have service with Telus previously with this phone?
10-10-2022 09:41 AM
This worked only if we’re on the same wifi. Otherwise the message says I’ve used up all my minutes then just hangs up.
10-05-2022 07:32 AM
Allow the message to completely finish and see if the call connects. If the last part of the message instructs you to press "*" do so without hanging up and see if your call connects. Report back your results.
10-04-2022 08:32 PM
Login to your account and click View Usage History but it doesn’t sound correct if you had 1 incoming and 1 outgoing calls. So contact a CS_Agent to have it corrected.
Remember that outgoing calls are rounded up to 1 minute.
Meanwhile, you can text your friends and family to call you for unlimited incoming calls or purchase 500 minutes for $5 as per @hairbag1
10-04-2022 08:09 PM
Get the $5 / 500 minutes of Canada wide calling add-on to get you going today.
Then contact CSA to look into discrepancies. Remember also...checking your voicemail uses up minutes too.
10-04-2022 08:01 PM - edited 10-04-2022 08:05 PM
Well that's not right.
Use the Get Help to submit a ticket to the CSA's if your usage history for past 30 days confirms what you've stated.
https://www.publicmobile.ca/en/ns/chatbot
EDIT: also try dialing 1+area code to see if that allows call to be placed...
10-04-2022 08:01 PM
No change after refreshing page. Even when I try to make a call the voice recording says I've reached my limit and can't.
10-04-2022 08:01 PM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
REFRESH, REFRESH, REFRESH
10-04-2022 07:58 PM
