08-21-2021 10:14 AM - edited 01-06-2022 03:13 AM
I'm stuck with Simon but the text page is shifted 25% to 33% to the left rendering the first third of the response being unreadable. So this makes communication unreadable. I still i don't have the use of my phone, My phone number was not transferred over from Telus to Public mobile but I can't talk to a company representative! Please HELP ME!!! anybody!
08-21-2021 10:19 AM
@Rusty1 Check your inbox, I have sent you the phone number for the Telus porting department.
08-21-2021 10:16 AM
It's not a win win if you can't communicate with them or them with you!
08-21-2021 10:19 AM
08-21-2021 10:21 AM
Perhaps multiple submissions to the Better Business Bureau! might elicit a response!
08-21-2021 10:27 AM - edited 08-21-2021 10:27 AM
it's a support model they chosen. Honest, nothing to complain to BBB
you have called the Porting team? They will give you a status update or what need to be done.
Let us know how it goes
08-21-2021 02:13 PM
Did you reply YES to the PAT (porting authorization text) ? Put your telus SIM card back in your phone and reply YES.....telus will continue to send you the PAT between the hours of 11 am et and 8pm et. Once you do that your port will complete within a few minutes up to 2 hours. Once telus SIM no longer works put the pm sim card back in your phone and reboot.
08-22-2021 10:59 AM
I can't switch from Telus to Public Mobile either. help. a phone number would be great. I've tried for two days to sort this out.
08-22-2021 11:03 AM - edited 08-22-2021 11:05 AM
@Elliott1 did you reply the SMS on your Telus to approve the porting?
so, only incoming calls and text not working?
I will private message you the Porting team phone number, they will give you the porting status and let you know if anything pending
**check Community inbox, envelope icon on the top right
08-22-2021 11:05 AM
@Elliott1 wrote:I can't switch from Telus to Public Mobile either. help. a phone number would be great. I've tried for two days to sort this out.
What have you tried so far? More details would be helpful. Is your phone partially working? Were you charged already? For a stuck port, able to send texts and talk out, unable to receive calls or texts.
08-22-2021 10:33 PM
@Rusty1 wrote:I'm stuck with Simon but the text page is shifted 25% to 33% to the left rendering the first third of the response being unreadable. So this makes communication unreadable. I still i don't have the use of my phone, My phone number was not transferred over from Telus to Public mobile but I can't talk to a company representative! Please HELP ME!!! anybody!
Have either of you got your services working yet?
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
If issues porting or transferring a number to Public Mobile, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
