03-12-2021 08:15 AM - edited 01-06-2022 02:17 AM
I am having difficulties receiving text and incoming calls.
I have taken my sim card out and turned off my phone.
03-12-2021 07:00 PM
@Vivian90 wrote:I had my phone set up over a month ago. It has been working perfectly until yesterday.
Stopped all incoming calls and receiving texts. I checked my account and they charged my month fee to my visa already.
@Vivian90 you had your phone plan for over a month....
If you have no services, and it is past your renewal, maybe your autopay failed?
Try topping up your account in your SELF SERVE or by calling 611 to your plan amount. If still no service (still saying suspended) go into the lost/stolen feature in your SELF SERVE account and hit "Resume".
Reboot your phone. All okay now?
Ensure this is not an issue:
https://www.publicmobile.ca/en/bc/get-help/articles/sim-swap-fraud
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
03-12-2021 12:52 PM
Is your account status active or suspended?
If everything was working for the last month, it likely is not a porting issue. Maybe your plan did not renew properly. Check your payment history. Sometime autopay does not work properly.
03-12-2021 11:29 AM - edited 03-12-2021 08:02 PM
Hi @Vivian90 it seems that your port failed. Check the envelope icon on top right... I sent your the number to call regarding porting problems.
RosieR
03-12-2021 10:13 AM
03-12-2021 08:44 AM
I assume you are porting number from old provder.
did you reply YES to an SMS from your old provider. If so, the port should be coming and it will be just another hour or two. Like what you are doing, just keep rebooting your phone every 15 mins.
03-12-2021 08:44 AM
@Vivian90 Did you recently port your phone number over to PM ? It can take several hours for the port to be completed.
03-12-2021 08:43 AM - edited 03-12-2021 08:44 AM
@Vivian90 wrote:I am having difficulties receiving text and incoming calls.
Are you new to Public Mobile having had just activated and/or porting a number from another provider?
You may just have to reboot, restart, remove/replace SIM, and reset network connections. Try this once every 20 minutes or so. Things should fire up.
Please refer to the following article which may provide guidance:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
03-12-2021 08:37 AM
did you just sign up for Public mobile? It took 30min or so before I could receive calls and texts even if I was able to make calls.
