08-09-2023 12:35 AM
Hello, is there a simple (step by step) guide to transition "My Account" from the old login (pre-Eversafe) to the current log in system without contacting CSA or PM support?
I need to update my payment info. So do I start by log in or sign in?
I don't have a Community account but I did search the community forum on this topic and it's very confusing. A friend is posting this for me and he said he needed multiple support with the transition.
08-16-2023 10:22 AM
A big THANK YOU for all your replies. I followed this solution exactly (step by step) and now I'm able to log back into my account (under Eversafe ID).
Please continue to keep solutions simple and easy to follow.
08-09-2023 03:00 AM
You'll be able to sign in using your previous credentials without any issues, follow the promots like confirming your Email Address, Name, and it might ask you to create a new Password.
It will text a code to your phone to confirm full access to EverSafe ID, after you enter the code you'll be set up. 🙂
Follow this link to add Funds to your Account: https://myaccount.publicmobile.ca/en/account/payment/funds/card
08-09-2023 01:34 AM
All new members are required to create an Eversafe ID. Once you created an ID, your email on the account will be the same as on this Community.
Go ahead and click on Sign Up on the Eversafe ID before login to your account.
Then go to the Payment section and click Manage Payment.
08-09-2023 12:39 AM - edited 08-09-2023 12:41 AM
so, you are using the same email address as your My Accountto login Community now? If so, click My Account link on top right or this direct link https://myaccount.publicmobile.ca/ and see if you can access My Account
If not, or if it shows you option like "Continue Activation", then your My Account is not properly linked. You have no choice but to contact agent to get the My Account properly linked with your email login
