Rate plan question
Wrenchguy_1970
I just signed up with Public Mobile.  Do these rate plan prices stay the same or because its a promo is it going to revert back to the original price?
2 REPLIES 2
colleeno
Plan prices will stay the same as long as you keep a plan. Plan offerings change quite often with Public Mobile so, if you change to another plan and then later decide to go back, your original plan may not be available.
hi @Wrenchguy_1970 the plan is a promotion meaning you have to join before it is gone.  But once joined, you can keep the price.  But if course PM cam increased price if they want, but it rarely happens.  The plan I had still same price after 5+ years but I changed to cheaper plan with more data myself
