Changed plans
Signalmen
I changed plans last month before billing cycles ended.   I'm still be charged at old plan. Postal shows my new plan but billing at old rate
funpig1
@Signalmen  That caching/delay messed my wife's subscription, too. Made it look like she was still on old plan when it was changed on renewal.  I had to exit out of her app several times before it finally for refreshed. Good luck.
Rastin
Check the bank/ visa first and see if you have been charged wrong. Also clear cash and use incognito private mode as some time is shows wrong
will13am
@Signalmen , are you using the app or browser to check your online account?  There could be a caching issue resulting in stale data being viewed.  Try using incognito mode if using a browser.  If using the app, delete app cache or reinstall the app.
EB0
What was your old plan and new plan?
